display port cable question
Solved by AbydosOne,
24 minutes ago, squallypo said:will this cable support 1080 resolution with 144hz?
https://www.argomtech.com/products/displayport-to-displayport-cable-m-m-6ft
thanks for the help.
ps: this is the only model they have in my country atm.
I don't see any reason why it wouldn't. 4Kp60 is equal to 1080p240 in terms of bandwidth.
