Hello,
So i have been trying recently to update drivers and everything for my pc since I added a ryzen 3700x. I have been having this problem with adrenalin that crashes with any update after 12.1.1. Like any game I open crashes, overwatch says rendering device lost and red just crashes, so i have to keep going back to that 12.1.1 and miss the optimization. Does anybody know what is going on?
Specs
ryzen 3700x
aorus b450 pro wifi
5700xt
3600 18 gb vengance
2 250 gb ssd
1tb hdd
650 psu
https://linustechtips.com/topic/1282325-amd-drivers-problem/
Did you go a BIOS update after you installed your new CPU?
SPEC LIST:
CPU: AMD Ryzen 5 2600x w/ AMD Wraith Stock Cooler
MOTHERBOARD: Asus ROG Strix B-450F
RAM: Corsair Vengeance Pro RGB 32gb 3200mhz (2x16gb)
GPU: Nvidia RTX 2080 Super FE
PSU: Corsair 750x 80plus Gold
FANS: Dual Corsair LL Series LL140mm Dual Light Loop RGB
MONITORS: BenQ ZOWIE XL2411P 24 Inch FHD LED 144Hz (DP)
Lenovo - G25-10 24.5" LED FHD 144HZ Monitor (HDMI)
PATIENCE: NOT CURRENTLY INSTALLED
P.S: STILL REALLY WANTING TO FIND SOMEONE WHO CAN CARRY ME TO GRAND CHAMPION IN ROCKET LEAGUE :)
P.P.S: I NO LONGER NEED TO BE CARRIED TO GRAND CHAMPION AS I HAVE MADE IT ON MY OWN 😁
https://linustechtips.com/topic/1282325-amd-drivers-problem/#findComment-14310398
2 minutes ago, noaimnolife said:
Hello,
Specs
ryzen 3700x
aorus b450 pro wifi
5700xt
3600 18 gb vengance
2 250 gb ssd
1tb hdd
650 psu
Are you running the latest chipset drivers from AMD? https://www.amd.com/en/support/chipsets/amd-socket-am4/b450
https://linustechtips.com/topic/1282325-amd-drivers-problem/#findComment-14310407
2 hours ago, noaimnolife said:
Yes I updated it to the 50 because the 42 was having trouble with my boot.
Go ahead and run DDU and remove your old drivers and do the fresh install.
SPEC LIST:
https://linustechtips.com/topic/1282325-amd-drivers-problem/#findComment-14311030
