Hi all
This will be complicated thread as there is current build and future one, im planning to build it all step by step starting with replacing my case as current one has terrible thermals and noise.
Order of upgrades : Case->GPU->PSU->RAM->CPU+MOBO->maybe liq cooling?
My current set up :
CPU: AMD Ryzen 7 2700X -> propably waiting for next gen along with mobo
GPU:  GTX 1070 FTW  -> RTX 3080 got option to buy directly at nvidia store thier standard one for around 620$  or 3070 for 450$ not sure yet..
MB: Asrock X470 Master SLI -> propably waiting for next gen along with GPU
RAM: GoodRam IRDM X 16GB 300mhz (2x8gb) (had 4x8 but were running really badly causing memory problems in memtest86) - replace for some proper one that will run decent on x470  and get 2x16gb at least 3600mhz, thoughts?
Case : Genesis Titan 700 - Biggest issue for now debating between Lian Li O11 be quiet! Pure Base 500DX, Cooler Master MasterBox TD500 Mesh ARGB, PHANTEKS Eclipse P400A DRGB
PSU: SIL PC VERO L2 600W BRONZE -> was thinking about Corsair RMx White 750W 80 Plus Gold, Gigabyte Aorus 750W 80 Plus Gold, Seasonic Focus GX 750W 80 Plus Gold
SSD :Samsung 850 Evo 250GB -> will add NVMe one 500gb or 1gb and keep both SSD and one HDD.
HDD:WD Gold 2TB
Let me know Your opions what i could do to get best results and not get stuck with unapgradable machine that i have now.
What case would fit my current and future build provide good cooling and relativly nice noise reduction. (i like that glass and lights :D )
https://linustechtips.com/topic/1281609-current-top-case-for-100-150/
I mean, any of those cases are gonna do well but my personal choice would be between the TD500 and the P400A. Pick the one you think looks better and run with it. The technical differences between each are gonna be minimal at best, and the majority of your noise/thermal adjustments can be done in software anyhow.
CPU- Intel i7-8700k
MOBO- Asus ROG Strix Z390-i
RAM - 32gb G.Skill Trident Z RGB DDR4-3000
GPU - Zotac RTX 2070 Super Mini
Storage - 1TB Intel 660p M.2 SSD / 2TB Intel 660p M.2 SSD
Chassis - NFC Skyreach 4 Mini - Black
PSU - HDPlex 400w Combo AC/DC & DC-ATX
