Budget (including currency): Around 3000 euro
Country: Netherlands
Games, programs or workloads that it will be used for: Rome total war 2, Abode premier, Sims, Plex 4k some direct play some not.
Other details So it needs to run 3 pc's and 1 of them will be a Plex server that also needs to run outside my home network for 5 users outside and 2 inside the Network.
Ill already have an NZXT H440 Razer edition case i wanna re use. have an 850 watt power supply from be quiet. and a Asus 650Ti gpu maybe thats usseable for Unraid again???
Hope you guys/girls can help me out with this and give me some tips on how to do this...
https://linustechtips.com/topic/1279047-3-pcs-1-cpu/
As far as video editing goes LTT made a video about a budget 4K editing rig which might give you some inspiration: https://www.youtube.com/watch?v=w_HKRUPN1Mk
Both Sims and Rome Total War 2 should be fine with your 650 Ti (a 650 is the official recommendation for Sims 4).
With Plex I'm unfortunately not very familiar. However I understand that you need quite a bit of computing power for seven simultaneous 4k streams plus two more virtual machines. I guess you will inevitably end up having to go for a Threadripper 3000 series CPU and at least 32 GB of RAM. For your host OS (e.g. Unraid or some other virtualisation friendly Linux distro) you'll want to reserve at least one or two cores, maybe check out one of the several virtualisation videos LTT made for reference.
https://linustechtips.com/topic/1279047-3-pcs-1-cpu/#findComment-14286655
Thank you for the help will look in to this!!
https://linustechtips.com/topic/1279047-3-pcs-1-cpu/#findComment-14286778
