Hello so it's my first time planning to build my own PC and I have some questions regarding the rgb headers and stuffs
The current build is as follows:
https://pcpartpicker.com/list/QMhhK3
CPU; Ryzen 5900x
CPU Cooler: ROG ryujin 360
Motherboard: Asus rog crosshair viii dark hero
Memory: g.skill trident rgb 16gb*4
Storage: samsung 980 pro 1tb*2
GPU: asus rog strix rtx 3080
Case: Asus rog helios
Power supply: Asus rog thor 850w
Aside from these parts I would like to add in an Asus rog aura terminal and run 4*30cm addressable led strip with it.
My question is will I have enough rgb headers for me to switch the fans on the ryujin radiators 3*120mm and the rear fan on the case 1*120mm to some other rgb fans
If so is there any recommendation for rgb fans that's aura syncable
Thank you would really appreciate any help.
https://linustechtips.com/topic/1278137-need-help-with-new-build/
