I have an old dell XPS system board and it has an I5 4 core processor but I don’t know what board I should upgrade to and if I should get a bigger or better processor. I also don’t know what graphics card to get. I also don’t know if the power supply from the XPS will work. To be honest I don’t know anything about building a computer can I ask for ideas and or help figuring out what to do.
I did buy a case with a tempered glass side panel and rgb lighting but that’s because I liked the way it looked online
https://linustechtips.com/topic/1275627-help-please/
do you have the model of the XPS?
I doubt the power supply would be any good for a gaming graphics card in this day and age, but we also don't know what kind of money you're spending
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1275627-help-please/#findComment-14261131
  • 3 weeks later...
I’m sending a over view of what I have so far and I don’t know if it’s going to do what I would want it to but if anyone would know it would be all who watch this channel as much or if not more then I do
https://linustechtips.com/topic/1275627-help-please/#findComment-14310751
The i7 4770 is about as far as you can go with that platform in terms of CPU. Best off just building an entire new PC. What budget do you have? What graphics card do you have?
Mobo says it's a maximus VI hero, you could get some decent money for that board if you sold it, that's not a standard Dell board though so not sure what system you have. Got any pics of the internals?
CPU - Ryzen 7 5800x3D |  GPU - RTX 3080 TUF OC | Motherboard - ASUS TUF X570 | RAM - Patriot Viper Blackout 32GB 3200MHz | Case - InWin 805 | Boot Drive - Corsair MP600 PCIe 4.0  Storage - 2 x 1TB SSD's & 1 500GB SSD | PSU - Seasonic Focus Gold 1000w | Display - ASUS TUF VG27WQ Curved 1440P 165Hz | Cooling - ASUS TUF LC240 AIO + 5 aRGB Fans
https://linustechtips.com/topic/1275627-help-please/#findComment-14310837
No idea what kind of money you want to spend but $400 can get a quality motherboard, power supply, ram, and CPU.
Though, availability is thin right now for AMD products so you might be looking at a 6 core i5 if possible.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1275627-help-please/#findComment-14310878
