Help with Targeting system
Is it actually faulty right now, as in is there symptoms of failure or just the damaged component ?
Looks like it may have blown apart enough to seperate, is it failed open or short ?
Check the size, ideally measure one to get the capacitance but as I said if for just general purpose decoupling it shouldn't be too critical. X5R or X7R temp coefficient should be fine.
0603 ?
So say pulling out of my rear end:
0603 1uF 16V X7R SMD Ceramic Cap
Note: This is just a stab in the dark, I suggest doing as much investigation of the circuit and topology, schematics if available and existing components.
You will likely have to order them in from digikey, mouser, RS, element14 or a local electronics store. Possibly order other gear as the shipping fee on a few SMD parts will suck.
Also how'd it short ?
