I bought a Razer Naga Trinity about 2 years ago and its been working great until now. The issue is that sometimes when I hold down the right mouse key it would release quickly causing a double click. It really isn't an issue in most of the time but it makes some games I play extremely difficulty. All of the other keys work perfectly fine. Is there any way to fix this? I would really hate to have to buy a new mouse. Thanks in advance
https://linustechtips.com/topic/1271787-help-fixing-my-mouse/
The only way to fix it is to buy new mouse switches from aliexpress/ebay and replace the broken ones. Are you sure that you aren't still covered by warranty?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/1271787-help-fixing-my-mouse/#findComment-14232674
