Budget (including currency):  Around 100 for power supply, either a little bit more or less depending
Country: United States
Games, programs or workloads that it will be used for: Some heavy gaming, also a CAD/ video editing workstation
Other details: https://pcpartpicker.com/list/2jhdbh is the parts list I'm working with right now, but I don't know what kind of power supply I will need for this. I'd prefer if it was gold rated or higher but I understand with the budget for it, it'll be gold probably. I'm gonna use an old GTX 760 until I can find a 3070 since its not in stock right now.
https://linustechtips.com/topic/1271245-need-help-picking-a-power-supply/
27 minutes ago, BiotechBen said:
@air_switch I'd recommend checking out the PSU Tier list for this question.
I was looking at it, but I don't know exactly what power supply wattage to get, I saw people saying there were big power jumps on the 3070 every now and then, but I'll take a look again.
when they were doing the reviews of the 3080 and 3090, there were huge power spikes under heavy load.  I'd say aim for 750W with plenty of wattage available from the 8-pin and 12v rail.
Alright thanks, ill look for a 750 gold rated
a 750-800 watt should suite you. but a single rail psu may interest you more.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
