-(Needless info explaining the background to the problem)-
I have a Asus Strix 1080 that has some slight sag to it (~0.5mm) and its been like this for years with no problem. Well yesterday when I was trying to get a 6800 xt, and of course failed, I got up from my desk and bumped my knee into it, killing my video output and causing my GPU to go full ps4 raid siren mode. After a reset everything was fine but I then discovered that any bump on my desk would cause my video to crash due to the GPU lightly shaking in addition to its slight sag. So I put a small pencil eraser cap at the bottom of my case to act as a makeshift GPU bracket (my GPU is placed at the lowest pci slot due to the MoBo chipset needing more cooling), this fixes the crashing problem.
-(The problem)-
However, after straightening the GPU my temps are now constantly above 85C in game, before they rarely peaked above 60C. Even with my case and GPU fans cranked to 100% the temps don't change. I've checked the GPU and no mounting screws have come loose and it has good thermal paste applied.
So now I'm kind of stuck between my GPU throttling super hard with the risk of breaking the card, and non stop crashing anytime I bump my desk.IMG_20201119_114122.thumb.jpg.80bcf0df3538ff4c764d142113e33a18.jpg
https://linustechtips.com/topic/1271084-gpu-sag-decreasing-temps/
I'm sorry, lifting the GPU 1/4 of an inch results in 25c increase in temps?
Also, if bumping your table results in a video card crash, that's a huge ass issue.  Lift it up and figure out what the real reason your temps are increased.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
I've been tinkering with it a bit and it seems like the years of being slightly bent have just permanently warped the GPU cooler "baseplate" (Asus cards don't have a proper baseplate, just heat pipes). So raising the GPU to a normal position is now not letting the cooler make proper contact with the GPU die.
Guess this is just a lesson in long term GPU sag, now I pray to the silicon gods to send more GPUs down.
