You can create your own installer for free using any working Windows PC you have access to.
Simply download the Microsoft Media Creation Tool, insert an 8GB or bigger USB drive, run the tool, select the USB and wait.
Afterwards boot from the USB and the installer will run.
Main Rig:-
Server:-
should i worry about virus or data crash anything?
btw, is that ok if i just download the iso from the microsoft window website itself?
Sure but you'll need something to create the USB for you.
Main Rig:-
Server:-
