12 minutes ago, solraCRM said:
I have a question about the memory speed displaying 1333MHz, is it because its running on single channel?
use the Memory tab to see actual speeds. Take the RAM frequency and double it to get your speed that your RAM is actually running at.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1268958-memory-speed/#findComment-14210556
You have 2667 MT/s DDR4. CPU-Z reports the physical speed which is 1333 MHz. This is correct for 2667 MT/s.
It's not because of single channel, and nothing is wrong.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1268958-memory-speed/#findComment-14210579
