pls help me ASAP
Go to solution Solved by ixi_your_face,
8 minutes ago, CutePanda said:
i was turning off the safe mode while playing pubg pc lite on the nvidia control panel, and...........
i accidentaly hit the restore option in the manage 3d settings- global settings and the display is likee too thin or idk how to say it, but there were black bars on the top and bottom. i prefer using 1280x768 res and when i checked the display option, its the same, i use a 75 hz tv as my monitor and in it it shows 1280x1024 res, i dont know how to change things back to normal. pls pls help meeeeee!!!!!!!1
[snip]
Check to make sure your desktop size and rotation are correct for your settings:
https://linustechtips.com/topic/1267301-pls-help-me-asap/
[snip]
"You know I was taught that if you don't have anything nice to say, don't say anything at all. You feeling me cocksucker?"
"Ethernet is internet juice. You have to press the internet really hard and you will get it."
"My quantum milk machine brings every boy to all the yards." non futuis et sursum
PC Specs! | I7-950 | 24GB RAM | 10TB Storage | GTX 970 Strix and a 560TI DCUII for Physx | 120GB 840 + 250GB 850 EVO | Asus xonar DGX
Please take a moment to look over the forum CoC here.
https://linustechtips.com/topic/1267301-pls-help-me-asap/#findComment-14196340
