MB: ASUS ROG B550-F GAMING (WIFI)
ISSUE: I am attempting to overclock my Ryzen 7 3700X to 4.2 GHz - 4.4 GHz, but it does not work. How does it not work? Well, I am able to set it to 4.2 GHz then when I restart all monitors are stay off, computer is stays on; motherboard light is a static orange DRAM light. Power button on case will not work, resorting to flicking the PSU switch. When I had a B450M, I was able to get 4.3 GHz. I need help please.
CASE: NZXT H510 ELITE MOTHERBOARD: ASUS ROG Strix B550-F Gaming (WIFI 6) CPU: AMD Ryzen 5 5600X 4.7GHz (ZEN 3COOLING: Arctic Freezer II AIO 280mm RAM: 32GB Corsair Vengeance RGB PRO 3200MHz CL15 GPU: NVIDIA RTX 3080 Founder's Edition PSU: Thermaltake RGB 850w 80+ Gold STORAGE: SSD Samsung 860 EVO 250GB // M.2 NVME WD BLACK 1TB // M.2 NVME Samsung 970 EVO 1TB // HDD Seagate 2TB OS: Windows 10 Home x64 Bit MONITORS: LG 27GN850-B @144Hz 1440p // Acer XF270H @144Hz 1080p MOUSE: Razer Viper Ultimate Mercury White KEYBOARD: Razer Huntsman TKL (w/ Razer Mercury White Keycaps) HEADSET: HyperX Cloud Flight
https://linustechtips.com/topic/1264870-help-oc/
7 minutes ago, Rogerzz said:
Are you increasing the voltage? Some chips are better than others, your chip might not be able to clock at 4.3GHz all core.
I have not increased the voltage, how and what would I change it to?
https://linustechtips.com/topic/1264870-help-oc/#findComment-14177248
Just now, Rogerzz said:
When you OC, you need to increase the CPU VCore voltage so it runs stable. Start at 1.29V and see if it boots. If it does, work your way downwards until it doesn't.
You need to test stability with Prime95, simply booting into Windows does not mean you have a stable overclock.
Okay I’ll try when I’m home, thank you
https://linustechtips.com/topic/1264870-help-oc/#findComment-14177258
I have a similar set up to yours. If you turn on your XMP profile and use FCLK (setting that to half of your clock i.e 3200Mhz = 1600Mhz) then the processor will run anywhere from 3.8 Ghz to 4.3, varying depending on the load. At least that is what happened to me lol
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1264870-help-oc/#findComment-14177282
I have 7 3700X on 4.3 GHz with 1.25 volts is that good? I tried 1.20 but I get the blue screen. Edit: Prime95 fail on 1.25 and 1.275. Attempting 1.29
Edited by DHV0
Fail
https://linustechtips.com/topic/1264870-help-oc/#findComment-14177617
4.3 GHz with 1.29v is the most stable. Prime95 with 16 workers, good. 3DMark Time Spy, good no crashes.
https://linustechtips.com/topic/1264870-help-oc/#findComment-14177697
