I would like to buy a white or silver color case which has non gamer look. It should have good airflow and the best situation would be if there is option to choose between airflow and silent. Like if there is a door which can be closed for quiet operation and opened for great airflow.
Case must support 360mm front radiator.
I was looking for fractal design r7 compact and I would remove front dust filters.
Would be great to hear suggestions. Thanks.
https://linustechtips.com/topic/1261286-case-for-me/
