The CPU fan typically has its own separate header. However, I doubt there will be 5 regular fan headers. My motherboard only has three. You don't have to get a fan hub though. You can just get a cheap fan splitter like this: https://www.amazon.com/Splitter-Computer-Extension-Converter-TeamProfitcom/dp/B07F8LV1BY/ref=sr_1_4?dchild=1&keywords=fan+splitter&qid=1602860357&sr=8-4
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1258345-mobo-fan-headers/#findComment-14122484
Off of Newegg they list these
1 x CPU Fan Connector (4-pin)***
1 x CPU/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
4 x Chassis/Water Pump Fan Connectors (4-pin) (Smart Fan Speed Control)*****
So technically speaking there are enough, but the water pump ones you might not be able to control speeds very well if at all.
*** The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**** The CPU/Water Pump Fan supports the water cooler fan of maximum 2A (24W) fan power.
***** The Chassis/Water Pump Fan supports the water cooler fan of maximum 2A (24W) fan power.
***** CPU_FAN2/WP, CHA_FAN1/WP, CHA_FAN2/WP, CHA_FAN3/WP and CHA_FAN4/WP can auto detect if 3-pin or 4-pin fan is in use.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1258345-mobo-fan-headers/#findComment-14122490
ok, but fan headers are better for cable management if you but it in the back portion of the case.
https://linustechtips.com/topic/1258345-mobo-fan-headers/#findComment-14122496
True. I helped a friend build a PC with splitters like that though and it was actually pretty easy to cable manage to where you didn't see them.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1258345-mobo-fan-headers/#findComment-14122503
