Hey guys. I'm planning to upgrade my i5 6400 to a i5 10600K and need a new cooler, because a stock cooler wont do the trick.
My question is: Will a Cooler Master Hyper TX3 EVO be enough? Or should i search for a more expensive solution
The cooler cant be above 156 MM in height because i have a relatively small case
Any answer is appreciated!
https://linustechtips.com/topic/1258334-i5-10600k-cooling/
1 minute ago, Rubrix said:
the problem is that that one is just slightly to big for my case
why wouldn't it be a good cooler tho?
10600k is power hungry, especially if you want to overclock it. the tx3 is quite entry level and not suitable for such a strong cpu.
https://linustechtips.com/topic/1258334-i5-10600k-cooling/#findComment-14122360
What cooler would you recommend that's smaller then 156MM in height and will do the trick?
https://linustechtips.com/topic/1258334-i5-10600k-cooling/#findComment-14122371
NH-D14 or NH-U12S if you have the funds or space.
Because of your space limitation then NH-U9S or NH-D9L
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1258334-i5-10600k-cooling/#findComment-14122386
those are too tall
Yea I realized that and edited my post, my bad.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
  • Cooling
  • Operating System
    Windows 11
https://linustechtips.com/topic/1258334-i5-10600k-cooling/#findComment-14122401
