Laptop Fix help
Go to solution Solved by Bombastinator,
The bracket is the tough one.  Maybe contact Lenovo and see if a replacement part is available?  Missing screws may also have stripped thread holes.
I Have noticed that my Lenovo yoga 520 has had 2 missing screws at the back and one of the brackets that doubles as a lock has been broken some how and will not fit in the machine but it is sticking out a bit above. I have tryed to push it down but will not work. Any Help would be greatly appreciated.
https://linustechtips.com/topic/1257827-laptop-fix-help/
https://linustechtips.com/topic/1257827-laptop-fix-help/#findComment-14117884
