mouse Mouse replacement suggestion
Solved by Yune_Faded,
Thank you Oswin and Godospartan for your recommendations. I had already done a bit of looking around myself prior to posting and was considering a G600 or G604 as you both was suggesting i just wanted to make sure i hadn't forgotten any brands like how i almost forgot corsair in my first look around. I think i am going with the G604 as i want to declutter my desk a bit and as Godospartan said could i have serval layers of profiles which if set up properly would be enough for my needs at the moment and if i need more further down the line can i always pick up a g600 or hope that they updated it so a wireless alternative exists
