MSI GS70 Cooling
Go to solution Solved by SkilledRebuilds,
My rule of thumb, I'm always using a cooling pad for my personal laptop.
Before this rule of thumb, I always elevated using some magazines giving 1-3cm's of lift under the laptop for a pedestal/desk fan to blow air underneath the belly of the beast.
Doing a re-install/anti-bloatware of another laptop recently, his i7 and GPU were pushing 60*c idle, but up to 95*c loaded, adding this elevation and fan brings it back to 71-75*c loaded.
Enough of an improvement to make me keep doing it.
I believe it will be fine just sitting down but a cooling pad would definitely help thermals inside such a thin and sleek laptop
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666554
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666566
is this on a gs70 or a different laptop? I need information about this product. Some laptops run cool, but others are like the blade and get hot
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666580
All laptops. But the one I mentioned the i7 and GPU was a performance gaming laptop, so closer to your temps from a powerhungry machine ,..thats why I added that to my post.
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666615
got it, but, was it a thin gaming laptop, or a fat one like a asus rog laptop?
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666787
In between would describe it best, thicker than my mums standard i5 lappy, but no where near some of the badass models I've seen.
https://linustechtips.com/topic/125370-msi-gs70-cooling/#findComment-1666935
