Replacement panels for repair?
So, I’ve just had a bookcase fall on my Dell U2913UM monitor. With it being on an ergo arm which swung out the way, the case itself has survived but the panel is buggered having cracked in a corner.
As the internals are still working, I’d rather try and repair it myself before shelling out for a new monitor and wondering if anyone can recommend where to get replacement panels from? It’s a 29 inch, 2560 x 1080 panel and preferably need from UK supplier.
thanks
https://linustechtips.com/topic/1249448-replacement-panels-for-repair/
