In line with the release of the 3000 series people have begun to say that you might need a pci-e 4.0.
I was looking at the 3080 for an upgrade and don't have a 4.0 pci-e slot.
Then I looked into the fact that Intel don't support 4.0 but some of the motherboards have it ready.
So my question is how much bottleneck are we looking at with a 3.0 slot. Is it even worth choosing Intel if upgrading since they don't support it yet?
https://linustechtips.com/topic/1249089-need-help-with-upgrades/
Steve from Gamer Nexus released a video just about it a couple days ago. Search for it on YouTube and you'll see. The difference is minimal, to the point it doesn't matter.
KitGuru also ran benchmarks and on Intel boards in some tests, the CPU seems to have a slight upper edge, which negates the need for PCI Express Gen4 at this moment.
https://www.kitguru.net/components/graphic-cards/dominic-moass/nvidia-rtx-3080-pcie-4-0-vs-3-0-scaling-analysis/all/1/
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
