Hello guys, im having a micro freezing problem on my system, it happens randomly, doesnt matter if im at full load or idling and it last like half a second, everything freeze and the audio becomes robotic. Im having this problem since ive changed my CPU, from a ryzen 1600 to a 3600x. In the past i thought it was some kind of incompatibility between my old MB ( gigabyte ab350m gaming 3) and the new CPU, but since then ive basically changed my whole system. Im now running:
CPU: Ryzen 5 3600x stock
MB : MSI x570 gaming plus
RAM:2x8gb crucial ballistix 3600mhz
GPU: 2080ti
PSU: Seasonic platinum prime 550W
HDD : 2 sata HDDs and 2 sata SSDs
everything is new except for the disks, now im wondering if one of them can be the problem, ive used latencymon and it seems to indicate that im having problems with interrupts:
Ive reinstalled windows many times , and im on latest drivers for basically everything on the system, ive also used DDU to be sure it wasnt caused by gpu and ive also tried a 1080ti and the problem still persist.
Is there anything else that i can try to isolate the problem? Can one of the disk cause such high interrupt times? Or is the CPU defective?
https://linustechtips.com/topic/1247855-continuous-micro-freezing-ryzen-3600/
