Budget (including currency): 14000egp(886$)
Country: Egypt
Games, programs or workloads that it will be used for: gaming and coding
Other details (I already have the cpu, gpu, motherboard and psu, I still need to buy an SSD, Ram and a case, I'm upgrading from an old laptop (i3 6006U 2 cores 2 threads, amd R5 m330), planning to finish my build by the end of this year and I want to know you opinion)
ryzen 5 3600 3300egp
RX 5500XT 3700egp
B450M steel legend 1700egp
hyperX 16gb 3200mhz Cl16 1350egp
addlink 256gb m.2 nvme ssd 1000egp
gigabyte P550B 500W 80+ bronze 1000egp
XPG invader 1400egp
total 13450egp(851$)
and if possible can someone do a benchmark for my build plz
https://linustechtips.com/topic/1244347-building-my-first-pc/
You may need more storage.
The SSD is great for fast booting your OS but 256 GB is not much. Some games need up to 150 GB nowadays, some 30 GB... So you could add something like a 1 TB HDD or if your budget is not that important, you could pick a bigger SSD.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1244347-building-my-first-pc/#findComment-14001205
Country: Egypt
RX 5500XT 3700egp
XPG invader 1400egp
Try Userbenchmark
https://linustechtips.com/topic/1244347-building-my-first-pc/#findComment-14001273
PCPartPicker Part List
Type Item Price
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory $69.99 @ Newegg
Storage Crucial P1 500 GB M.2-2280 NVME Solid State Drive $59.99 @ Adorama
Case Corsair 275R Airflow ATX Mid Tower Case $79.98 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $209.96
  Generated by PCPartPicker 2020-09-10 19:20 EDT-0400
https://linustechtips.com/topic/1244347-building-my-first-pc/#findComment-14009950
