3 minutes ago, ShrimpBrime said:
Download App, Throttle Stop.
Open and go to FIVR button and click it.
Check the box "Disable and Lock turbo power limits"
Click ok and close the menu.
Open TPL menu.
In this menu you can change the turbo time limits.
Hope this helps.
but i have intel xtu already and it makes the pc confused
https://linustechtips.com/topic/1243979-power-limit-throttling/#findComment-13998166
