RGB help!
So I found the answers.
I should update here for anyone who needs help.
Yes the ARGB hub will take 3 MF120R fans easily on a single header.. 2.6A is a lot of headroom.
So 3 AIO fans RGB with the 5-way splitter on one header.
AIO pump RGB on one header.
3 case fans on three headers.
And the 2 Neon Phanteks cables daisy chained and connected to one header.
That's all 6 occupied nice and clean
The CM controller hub that comes with the AIO is great with its magnetic mounting but it's way too many cables in and out and you need further splitters to fit everything. The case hub that comes in the GT301 by ASUS is a great inclusion. Aura Sync all the way
And yes... The Phanteks Neon strip comes with a cable that allows you to connect to normal ARGB headers. It converts the ARGB to DRGB (DRGB is not ARGB).
