I have i7 4710HQ in laptop lenovo y5070 with 1TB hdd model. I am using linux ubuntu 18.04 version the cpu temps are way above normal while using firefox and just 1 tab opened.. I have got it serviced 8 months before getting new thermal paste and cleaning. What should i do so that i can improve it. Does i need to take laptop to local technichian? if yes then how can i verify if the things are properly done?220319370_Screenshotfrom2020-09-0620-21-46.thumb.png.fd43a7aa8053b45f0756cbea68e9f509.png
https://linustechtips.com/topic/1243677-cpu-temps-are-not-getting-low/
Those temps look fine. It's a laptop. It's going to run hotter than a desktop PC, but your temps are still under thermal throttling levels. As such, you're fine.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
try using fresh thermal compound if you have the resources to, and making sure heatsink is seated properly and not disloacated
CPU: AMD Ryzen7 2700
GPU: RTX 2070 Super Founders Edition
Mobo: B450M-DS3H
RAM: 32GB Corsair LPX DDR4 2600mhz
SSD: 480gb Inland
HDD: 6x 2TB WD Black 7200rpm
