Budget (including currency): 1600 or less usd
Country: USA
Games, programs or workloads that it will be used for: Mostly gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Already have a complete setup been running off laptop so nothing setup wise is needed, 3440x1440 @ 144hz
Current List
Question would be does it matter between a 3600 or 3700x also if anyone has any experience with powerspec power supply's and if they were good for you
https://linustechtips.com/topic/1243057-first-build-3080-cpu-recommendation/
I wouldn't go with an r5 3600 and then a 3080, it would be an imbalanced system. Also, go with a good power supply from the forum's power supply tier list. The 3080 draws a massive amount of power and you don't want to cheap out with something that expensive in your build.
