Hello,
I’ve built my first PC 3 weeks ago. Yesterday I’ve updated one of the motherboard drivers and I’ve noticed that just before the PC completely shuts down I can hear that beep sound. The system is overclocked. When I changed the system to stock or turned on the game boost, the noise was gone. I’ve attached a video.
https://linustechtips.com/topic/1240722-beeping-noise/
5 minutes ago, CircleTech said:
Hello and welcome to the forum!
I have some server motherboards that do that. When they power off, the onboard speaker makes a little beeping sound right as it shuts off. It doesn't mean anything is wrong with your PC and it's perfectly normal.
Is it normal that it does not happen when the system is not overclocked? The sound only started yesterday. I assume it would be always there from the very start, not just from yesterday.
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13972807
1 minute ago, ShrimpBrime said:
Gotta list system specs.
Intel i7-10700k overclocked to 5.1Ghz
motherboard: msi z490 tomahawk
gpu: Gigabyte GeForce RTX 2080 SUPER Gaming OC 8GB GDDR6
Ram: Patriot Viper Steel, DDR4, 16 GB, 3600MHz, CL17 overclocked to 4200 MHz
PSU:SeaSonic Focus GX-750W
cpu cooler: be quiet dark rock pro 4
ssd: Samsung 970 EVO Plus 1 TB
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13972829
Nice rig.
So the beeps, only happened once?
Beep codes can be found here.
Should direct us to why hopefully.
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13972855
Nice rig.
This beeps happens every time I shut off my pc. I’ve stress tested my pc for an hour today and all the temperatures and components looked fine. When I went back to stock system, so 3.8 GHz, the beep was gone. The beep started happening yesterday after I’ve updated the motherboard driver.
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13972860
Basically I turn off my pc and just before it shuts down completely it beeps. I’m a noob with PCs so those codes are like foreign language
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13972865
9 hours ago, ShrimpBrime said:
Yeah, shouldn't be doing that.
Most beep codes are at start up or post, not during shut down.
Have you ever updated the bios?
Yes, all the drivers are up to date. Could this be because there is no enough power in some components?
https://linustechtips.com/topic/1240722-beeping-noise/#findComment-13973664
