Need help choosing a PSU (budget rig, RU)
Solved by Juular,
For the record, since you're apparently Russian, you'll get help on Russian forums quicker, on this 4pda.ru thread for example, which i sometimes read too (far less frequently in the recent weeks tho since quarantine is now over and i don't have nearly as much free time). But since you're here, out of these three i'd probably choose Chieftec BDF-S, then Xilence Performance A+ and then Zalman GigaMax GVII. If price difference between them is significant for you, you can just go for cheapest of these tho, they all should be good for this build.
