I have a Razer Naga Epic Chroma. This is the only mouse I could find that has 12 buttons on the side and is wireless. It was running semi-alright, I had a problem where if I switched from wireless to wired, it would disconnect my keyboard and reinstall its drivers, then crash my game. I ran a program called DriverHub to try and fix this problem. I usually never use these kinds of programs to install drivers, but I had tried everything else short of a reinstall of windows.
Now, Razer Synapse 2 wont recognize my mouse. I have tried reinstalling countless, deleting all leftover files from the previous install. I even just reinstalled windows. But nothing works. I need to be able to switch my DPI.
If anyone has any ideas, please help.
https://linustechtips.com/topic/1236699-razer-synapse-2-not-recognizing-mouse/
Try synapse 1 and another thing modded drivers isn't detected in synapse I'm pretty sure
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Are you using a fresh install Windows 10? I'm wondering if the Windows drivers somehow made it so Synapse 2 isn't detecting your mouse. I know when I do a fresh install of Windows 10, it will pop Synapse 3 up to install. I know when you install Synpase 3, Synapse 2 will no longer detect your hardware. Perhaps try installing Synpase 3?
I don't have modded drivers, I reinstalled windows. I'll try synapse 1, didn't even know it existed.
It's a reset of windows. I didn't get a popup to install Synapse 3, and Synapse 3 doesn't support this mouse.
26 minutes ago, AdvilLobotomite said:
I don't think Razor synapse 1 is a thing, I googled it and found nothing.
Hmm weird it maybe isn't called 1 but I've had it can I get images of the synapse you are using?
Reminder⚠️
But you said you installed some driver thing
Reminder⚠️
