1 minute ago, Mr.Moustache said:
So Im looking on building a new system now but all i need is a keyboard.
Im in Australia and my budget is $100 AUD
It must be mechanical and preferably from a reputable like Logitech, razer etc. Please NO CORSAIR :/
https://www.amazon.com/Razer-Huntsman-Tournament-Tenkeyless-Keyboard/dp/B07V25YPVW
https://linustechtips.com/topic/1236205-need-help-on-keyboard/#findComment-13938016
https://linustechtips.com/topic/1236205-need-help-on-keyboard/#findComment-13938065
10 minutes ago, Mr.Moustache said:
@nox_
I went to gmmk's web but when i refreshed the tab the price converted to Aud and it was $150 :/ I was shocked as i've never seen this brand before
Brand is reputable,makes much better keebs than corsair. Sad about the price. I would recommend this https://www.amazon.com.au/GK64-Hot-Swappable-Mechanical-Keyboard/dp/B0887V884D/ref=sr_1_25?crid=178GSVT5SXFDZ&dchild=1&keywords=gmmk&qid=1597840381&s=computers&sprefix=gmm%2Ccomputers%2C781&sr=1-25 if you are okay with the layout, it's a hotswap which means you can change the switches very easily later if you like. It also has usb c, rgb and even has decent keycaps.
https://linustechtips.com/topic/1236205-need-help-on-keyboard/#findComment-13938088
