Ethernet Throughput Spikes
Solved by -Rain-,
I found out my problem.
I have formatted everything, installing windows and such once more, but did not work.
Bottom line:
The GPU was connected to a PCIe 16x but was a 4x
I needed to switch places for the GPU and SoundCard.
It was my own fault for not reading the manual of the motherboard.
This Topic can be closed or removed.
