Evening all,
I want to replace my air cooler with a 360mm AIO but I want to know if I can use 3 of the fans I already have in my system (Corsair ML120) with the rad rather than the ones it comes with.
For info, my Lian Li O11 Dynamic has 3 ML120s at the bottom (air in) and 3 on the side (exhaust).
At the moment I have no preference for AIO, it just needs to perform well and look good.
If I can't use my current fans, could I put the AIO rad on the top? The PC would then have 8 or 9 fans, depending on if I go with a 240mm or 360. Is that feasible?
Cheers.
O11 Dynamic
Ryzen 3700x
Asus X570 Tuf
Asus 2080 Super
Love not hate
https://linustechtips.com/topic/1224675-adding-an-aio-to-my-system/
Yes and yes
You can use your own fans and a 360 will fit.
I would recommend a cooler but if you going to use your own fans just pick 1 you like a go with it.
Ah I guess I still recommend them.
Arctic liquid freezer 2 360/280/240 and chart leaders and out perform cooler double their cost.
Eks new aio can't think of the name is also really good.
