i need to upgrade but i'm on budget  what should i get
hd 7850 2gb with thermaltake 600w  or fx 6100 with gigabyte GA-990XA-UD3  this system is going to be for gaming playing games like dirt 3 crysis 2 and 3 on medium
i got
intel pentuim e5700 3.00ghz
4gb 1333 mhz
jetway ti41m
no graphics card i'm just runing the onboard video
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/
Whats your budget is my question??,
For the best improvement i would recommend the processor and mobo, the reason is because the new processor is better at gaming the the built in graphics with Intel so try the APU, you'll see a big improvement if you need more power and have some money left over get a card to improve performance
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/#findComment-130740
i have 400$ for the upgrade
and thanks man you are really aweome
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/#findComment-130753
You will need to upgrade your platform (CPU+motherboard) & add a graphics card to play games.
for 400$ you can build a decent gaming system but I would highly recommend saving up just a bit more to allow for a better upgrade.
You can recycle some parts from your old build, like the case, the screen, peripherals & possibly the power supply if it's decent enough.
Here is what I would recommend :
CPU AMD Phenom II X4 955 Black 3.2GHz Quad-Core .............$91.00
Motherboard Asus M5A97 R2.0 ATX AM3+ ................................$84.99
Memory Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1600 ......$47.98
Storage Seagate Barracuda 500GB 3.5" 7200RPM ....................$55.01
Video Card HIS Radeon HD 7850 2GB .......................................$179.99
Power Supply Corsair 500W ATX12V ..........................................$49.99
Total.............................................................................................. $508.96
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/#findComment-131071
AMD just dropped their CPU prices, so the build is now slightly cheaper ^__^ .
http://linustechtips.com/main/topic/12280-amd-slashes-cpuapu-prices/
CPU AMD Phenom II X4 955 Black 3.2GHz Quad-Core .............$81.00
Total.............................................................................................. $498.96
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/#findComment-131163
Just below the $500 mark, impressive!
https://linustechtips.com/topic/12245-need-help-for-my-upgrade/#findComment-131199
