When my frames go under 160 fps it starts to do vertical "screentearing" but only in some areas on my screen this disappers when using windowed mode and going back in fullscreen but only aslong as i dont tab out and in again. VSync or locking my fps dowsnt seem to work and this only appears to happen on directx games and never on Vulcan games.
GPU: RTX 2070s
https://linustechtips.com/topic/1224234-artifacts-in-fullscreen-mode/
This could be caused by a issue with a driver or something to do with a problem with your monitor could be wrong but worth a try reinstalling your drivers. I don’t it’s an issue with the monitor but a software bug could be the issue
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
yea i also thought this way but even after a clean windows installation it still appears and its happening on both monitors one is connected with displayport and one with hdmi
It’s possible it’s just a bad gpu if that’s the case just get a new one or try to find someone who can attempt to fix it. If there’s any other ports on the card try them. That’s my advice
System Specs
Peripherals
<Razer Mini>
i will try a different gpu and maybe older divers if that doesnt help i will probablly have to get a replacement.
