Hey all I have ended up with a sapphire hd6970 and a sapphire toxic hd6950.
I have a 1440p monitor, i5 2500k and a hx650 psu.
I have been happy with the 6950 for 18 months. I was going to replace it as I thought it was loud but it turned out its one of my fans on my CPU cooler.
I thought the hd6970 was faulty as it would shutdown at boot. But it seems to be working fine with a 2nd reset of the motherboard bios.
Question is what would you do?
I don't think my psu would handle crossfire.
I don't play FPS mostly RPG
I plan on doing a refresh of my rig late this year early next anyway. New case, fully modular psu, thinking about custom loop, if haswell is a lot better then sandy may swap that also.
My current thought is to sell the HD6950 now use the 6970 till I refresh and replace everything.
i7 5820k, Asus X99 Pro, 16GB Muskin Blackline, EVGA GTX 980, Corsair Air 540, Samsung SM951 256GB M.2, Samsung 830 256GB, Seagate 3TB, Ducky shine 4 MX clear & brown, Logitech G700s, Asus PB278q
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/
I'll definitely stick to AMD if their frame times will be fixed. Currently I own 2x 680s (see my sig) and I'm NOT HAPPY with them. They can't overvolt and they downclock when temps get too high. They pissed me off and I'm never going green again for next upgrade.
As for your situation, I suggest CFX them since only Nvidia is rumored to have their next gen soon. No news from AMD yet.
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-130655
I would suggest selling your 6950 & upgrading within a few months, even if you don't end up buying a 700 series card, their release is bound to have an effect on pricing.
Last we heard the first of the 700 series is coming in about three weeks.
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-130751
definitely get a next gen 700 series card...some series improvements there. and besides the old 6900 series of cards by amd weren't that great in my opinion. just tweaked 5870s. but anyway 700 series is right around the corner. probably get a gtx 770 or 780 if u have extra cash :)
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-130777
The 6900 series wasn't tweaked 5870s, it was a completely new set of GPUs.
The 700 series on the other hand is just a re-badged 600 series, the 770 is a 680 & the 760 Ti is a 670. (Allegedly)
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-130804
Assuming your PSU can handle them, CF them since you have a pretty high res monitor. You'd need all the rendering power you can muster and the HD6970 + HD6950 would make a pretty potent combo. With them in CF, you should be able to handle most games High - Max @1440P.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-131240
a 7870 will beat the 6970 and the 7850 can even beat the 6970 in some games. If you can get the 7870 LE then that is better
Listen if you care.
https://linustechtips.com/topic/12235-keep-6970-or-upgrade/#findComment-131831
