Streaming help
Go to solution Solved by Skiiwee29,
1 minute ago, TylerLovekeeper said:
here
mmmk, 1080/60 is super hard on a single PC setup, so you're likely hitting a CPU bottleneck. Try changing your ouput to 1600x900/60 or 1280x720/60. Also, there is a windows scheduler bug with OBS. You will need to run OBS as administrator to force it to allocate the appropriate resources otherwise its treated as an after thought.
Hi there folks,  I don't understand whats wrong... I have downloaded OBS and ran the auto setup wizrd and used those specs. and everytime i game or stream its just laggy. It doesnt matter if I play single player, multiplayer, BR or story games.  Hell Even pokemon TCG Online lags while streaming.
PC specs
EDITED TO ADD GPU
GPU    RX 590
Cpu  Ryzen 7 3700x
mobo  MSI x570 gaming edge wifi
ram  Gskill 16GB ddr4 3600
Corsair 750m psu
2x m.2 ssds
2x 500gb hdds
also attached a couple pics
https://linustechtips.com/topic/1221780-streaming-help/
open OBS settings and take screenshots of your Output and Video tabs.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1221780-streaming-help/#findComment-13819265
sorry  added gpu      RX 590  so no nvenc
Video tab?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1221780-streaming-help/#findComment-13819296
here
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1221780-streaming-help/#findComment-13819312
will try and report back
https://linustechtips.com/topic/1221780-streaming-help/#findComment-13819315
so running as admin and setting to 720p output my buddy said its not lagging.   Ty for your help and ill make sure i run as admin each time
https://linustechtips.com/topic/1221780-streaming-help/#findComment-13819335
