so im doing a build in a Meshify C and im currently planning on running 2 NF-A14 Chromax fans (mounted as low as possible without touching the PSU shroud in the front and 1 in the top rear and one NF-S12A Chromax in the back. ill be running a NH-U12A on an X570 Aorus ULTRA mobo with a GPU in the top pcie slot. how can i optimize my airflow and fan configuration to provide the best cooling to my components? will the top exhaust help at all? feel free to swap the fans out for other noctua chromax fans or or add/remove fans (cooler will not change).
EDIT: to add another question, should i bother buying splitter cables for the front two fans? should i run them individually or together?
my pronouns are they/them
https://linustechtips.com/topic/1221394-meshify-c-airflow-optimization-help/
