To start off, I know that a lot of this based on opinion, which is why I posted this publicly instead of sending a dm to some people. Now that that's out of the way, in your time (past or present) with budget builds, did you often feel the need for something at the higher end, or was/is your overall experience satisfactory or better? And secondly, for people who have upgraded to a better build, would you be able to go back down to an $750-900 build  and play with say 1080p medium/high settings?
@Johnny-Boi or DM me on discord
@King of Reeeeee Land#9814
PC is a work in progress, open to any tips and suggestions with ways listed above 😉
https://linustechtips.com/topic/1220979-question-on-low-mid-range-builds/
5 minutes ago, BlueScope819 said:
which is not the case for your Optiplex because you are stuck with a 4770 or whatever
what optiplex? were you talking to the other guy
@BlueScope819 so a 3600 and 1660S is fine (i don't want ti because of the miniscule preformance increase that comes with it )
8 minutes ago, BlueScope819 said:
I mean a 1660S is really underpowered compared to a 3600 you should pair something like a 2070S with a 3600, you would be just fine with a 3100 or 3300x if you can find one in stock at MSRP
i'm just trying to be ready for when i do upgrade my gpu to a 2060 or 2070
@BlueScope819 i would probably end up using for at least four or five, and then i'd give it to my little brothers
10 hours ago, BlueScope819 said:
You wouldn't charge them for it? I can already imagine the marketing:
how much should i charge a couple of young fortnite kids for a 1660S
29 minutes ago, BlueScope819 said:
So you are considering building a new system or upgrading the one you currently have? Buying a 1660S just to hold you over 2 months isn't really a great idea, as it's like $5 a day worth of value lost.
i only make $112 a month, and i've been saving for this thing for 4 months already, and you the time that i buy it, it'll be like january or february, and i'd prefer to get into pc gaming faster, and upgrade a little bit sooner than i maybe should, but if the price of the 2060-2070S drop when the 3080-Titan Rtx 2 and the amd and intel gpu lineups come out, then i'll buy sooner
@BlueScope819 i also wanted to just say thanks for all the help you've been giving me lately, i really appreciate it.
Outsource chores, if that's a thing still for you?
lol, yeah it is
20 minutes ago, BlueScope819 said:
So what do you have currently?
a broken craptop
21 minutes ago, BlueScope819 said:
Depending on your budget
i'm looking at around $1400-1600 on the full setup, preferably lower, but higher up is fine
24 minutes ago, BlueScope819 said:
you can set up another user account for each of your brothers and charge them like 5$ an hour to play, which assuming ~4 hours a day that would be $600 a month
you really know naive fortnite kids (not that there's anything wrong with it)
@BlueScope819 planning to save in the future, also with the whole diminishing returns after $1,200 do you mean for a setup, or system. because if you can guide me to a good 1080p setup for $1200 that will work for a couple of years and can be considerably easily upgraded i would love that. also in case you didn't get what i meant, it's 1600 max for everything anyway, it's almost 12 here gotta go
What state are you in may I ask so I can determine if you have access to a microcenter?
florida, just north of tampa, and 3-5 hours from microcenter i think
Just now, BlueScope819 said:
Well, perhaps you might not need a new PC at the rate COVID is going down there. Good luck.
what does that have to do with anything
1 minute ago, BlueScope819 said:
I probably shouldn't have made the joke that everyone down there would be too dead to need a new PC
no, no you're right, this place is overrun with unmasked karens, and other dumb people who are quickly dying, i mean, not as bad as it could be, but it's bad. thankfully no one i know had been effected, anyway, this a tech
forum so i should stop
