I recent bought and installed a new h100i into my build. (Baby PC builder here, don't judge too harshly)
Following what I've seen many other people do with their builds, I tossed the stock fans and used 2 SP120s I got from a friend. Everything works fine HOWEVER my friend lost the resistors (step down/silent adaptors) that came with the fans. So they run at 100% all the time, and are quiet loud. Not good when you're going for a SILENT BUILD!
Does anyone know where I could buy replacements, or how I could get/buy some from Corsair???
I'd prefer them over another fan control so I can keep everything run by Corsair Link.
THANKS LINUS COMMUNITY!!
https://linustechtips.com/topic/121908-h100i-parts/
Plug them in to your motherboard CPU header(s) and you should be able to control them fine with the included software that came with your mobo. Free and cheap solution :D .
Plug them into your motherboard and change the speed
Damn it you were faster :P
Interested in Business and Technology
https://linustechtips.com/topic/121908-h100i-parts/#findComment-1623014
I would deff do this however I only have 1 fan header left on my board. And the Corsair Link header plugs in the CPU fan header. Plus I don't know why, I can't get AS Suite to DL properly. Tried at least a dozen times, from disk that came with mobo, and online and no luck.
https://linustechtips.com/topic/121908-h100i-parts/#findComment-1623038
the corsair link uses the USB cable from the controller/pump to USB header on
motherboard. the pump tach (single wire) can be put on any 3-pin header
(CPU_OPT works well).
https://linustechtips.com/topic/121908-h100i-parts/#findComment-1644927
