Buying a front panel USB hub with an extra audio header. My OCD makes it very hard to think about not being able to use both headphone/mic ports(one on the case, one on the hub) and I was wondering if anyone knew of a PCIe card or header spliter I could install to make both ports usable.
Main Rig: i7-8086k 5.2ghz on ASUS ROG Maximus XII Wi-fi Z390 with Fractal Desgin S36 Cooler, 32gb 2400mhz, EVGA XC3 RTX 2070
Windows 7/XP hybrid rig: i5-3240(soon to be i7-3770k) on ASRok Extreme6 Z77 with stock cooler, 12gb DDR3(speed varies), GTX 980 FE, Cooler Master
Windows 98 Legacy Rig: Pentium 4 3.2ghz on socket 478 Intel D865GBF with stock cooler, 768mb DDR, FX5500 256mb AGP
All have several add-on cards including USB, Parallel/Serial, audio/game ports, and modem cards.
Monitors: 1440/165hz, 1600x900 and 1280x1024 for main rig, Hybrid and 98 rigs share a 1366x768 TV.
https://linustechtips.com/topic/1218500-audio-header-expansion/
looks like there's typical Y-cables at the usual suspects.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1218500-audio-header-expansion/#findComment-13790978
Namiste
https://linustechtips.com/topic/1218500-audio-header-expansion/#findComment-13790981
