Hello everyone on ltt fourms
I need help with my bew build
First my pc parts
Mb: asus tuf b450m plus gaming
Cpu: ryzen 3600
Ram: 16gb 3200mhz
Psu:corsair rm750
Gpu: rtx 2070s
Case: corsair crystal 280x
So i am trying to build this but i have some problems
I installed aio cooler (corsaie h100i rgb) with 2 120ml fans
So i have some issues with cables
Each fan have pumb header and rgb i connect the rgb to node pro however for the pump i connect it to this photo
Now the thing is there 4 headers there 2 with number 1 on it and 2 have no numbers so i don't know witch one to plug
Second thing is when i try to install the cpu cooler some thermal paste were touching the cpu but i kept pulling it out more then once is it fine or i need to redo it?
For the front panel cables i have 4
Reset sw
Power sw
Power led +
Power led-
Now in the manual i don't know where to put the reset sw and power sw so where do i connect them?
Last thing is the airflow should i keep the same path of airflow or change it? Gone post photos
Thank you...
https://linustechtips.com/topic/1216487-need-help-with-new-build/
Alright new update i cable mangmet everything in the front also i look at the motheboard itself to see the cables headerd so its all good now
Now i have to plug my psu cables
I also put my gpu and i notice it hage bracket to use it on bottom of gpu but i am not sure how to install it right i try to find youtubes videos but no results ( my gpu only wiggle abit with force of my hands)
Also i kept using my cpu fans like in the first photo since the motherboard have 1 cpu fan and 2 case fans( 2 fans from aio cpu and 2 from the case) so idk if i keep it like my first photo or not
Also aio have to be at the top since there no space for the front with the gpu
