Hi Everyone,
So on startup one fan on my GPU (5700xt) immediately jumps to 100% and was staying that way no matter what. Temps are normal (30 degrees), and its not drivers (which I've reinstalled multiple times). Turns out that if I push in the GPU to the mother board gently on the right hand side then the fans slow down. As soon as I remove my hand however the fan shoots back up to 100%.
Is this a card or MOBO issue? Im going to RMA the card if I cant fix it.
Motherboard is MSI B450-A Pro MAX
https://linustechtips.com/topic/1211768-pushing-gpu-into-motherboard-solves-issue/
did you try take the card and put it back? PCIe connector is long so it's not uncommon to take multiple tries before it fits flush.
Desktop benching:
