I just installed a GTX 780Ti in my main rig and I've been trying to get this ShadowPlay feature to work.  It hasn't work for me yet and it's kind of a bummer.  Was looking forward to this stuff.
What I'm working with:
- 4670K stock
- 8GB G.Skill Sniper running at 1600
- AX860 PSU
- Gigabyte G1.Sniper Z87 (rev 1.1) mobo
I can get the program up just fine.  Log into Twitch, set my file locations just right.  My keyboard shortcuts work because when I use them I get the indicator icons but with red lines through them.  Neither Twitch streaming or the manual recording work (with or without the shadow record).  I've tried to repair drivers, I've un/reinstalled GeForce Experience.  I've even tried to install an older version (1.8.00....er something), but that just would not install ShadowPlay at all.
The GPU itself works great.  I've thrown some Kombustor at it and gamed a few hours on it.  It hold up just fine, well within tolerated temps.
Not sure where else go from here.  Forum searches and  contacting support are what I gotta work with.  So any help would be great and much appreciated
Thanks!
https://linustechtips.com/topic/120912-shadowplay-not-working-help/
well first of all old versions dont support it so that doesnt really make sense.
use the latest BETA geforce experince with the latest BETA drivers and see if that works
if not u can use OBS witht he latest beta drivers and check nvenc which will use the hardware h.264 enocoder for streaming like shadowplay does
Would the BETA geforce experience be any different than what's available up front on the website?
Anyhow, OBS is a great alternative, it was what I was first looking at before that whole ShadowPlay came around to make streaming even more stream lined.  I'm happy with using it.  Thanks needmorewood
beta geforce would have the newer Shadowplay "application" to get the beta u just go into geforce experience settings and check something pertaining to beta.
yea OBS has the feature that made Shadowplay Unique anyways so yea!
