I'm struggling with connecting my  PSU to the CPU power on my motherboard.
My motherboard is ASUS ROG STRIX B450-F with an EATX12 port for CPU power. There are 8-pin ports on my modular PSU which are labelled 'CPU/PCI-E'. I only have 8-pin to 4+4pin connectors. The 8-pin end can go into either the PSU or the motherboard but only half of the 4+4pin end can go into the motherboard. The motherboard instruction manual says to use an 8-pin connector.
- Is my PSU incompatible, do I need a PSU that comes with an 8-pin to 8-pin connector?
- Is it just an issue of not having the right connector?
If anything is unclear I'll try and clarify, thanks in advance
https://linustechtips.com/topic/1207278-eatx12-help/
If it fits it does not mean it can fit
The wiring is different
Make sure it's the eps connector
Usually it says cpu on it should fit
8 pin breaks to two parts
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1207278-eatx12-help/#findComment-13701223
@TofuHaroto
I'm confident that it is an EPS connector, it's listed in the manual as a EPS/ATX12V 8(4+4)-Pin.
It says CPU on both the 8-pin end and on each of the 4-pin connectors. It also says GQ on the 8-pin end.
Yes, the 8-pin is split into 4+4 but only one side fits into the port on the MB.
Edited by ChooChoo22
https://linustechtips.com/topic/1207278-eatx12-help/#findComment-13701250
17 minutes ago, ChooChoo22 said:
@TofuHaroto
you have to make sure both sides of the 4pin are actually clipped together to form a single 8 pin block. that goes into the motherboard. make sure that the clip is facing the correct direction with respect to the ridge on the motherboard connector.  usually facing upward iirc.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1207278-eatx12-help/#findComment-13701290
