so I'm a complete newcomer when it comes to building my own PC and i built it correctly, it runs but when i tried playing a low demanding game ( enter the gungeon ),
the CPU usage goes to 93.8%, CPU temp is 50C and memory usage is 2243 MB, even though i didn't add any GPU and using integrated graphics i see a lot of people testing out higher demanding games , with the same IGPU. i need some guidance on why the fps (7fps) is so low and why the CPU usage is so high when playing my game .
specs :
Ram: 2x8GB, dual channel slots 3000MHz
CPU: Ryzen 3 3200G, 3.6GHz
GPU : integrated graphics : Vega 8
Motherboard: MSI A320-A pro max
Thank you in advance.
https://linustechtips.com/topic/1206758-cpu-usage-high-slow-fps-help-please/
Do you have the latest drivers ?
Do you have xmp/ dcop on ?
Is your fps consistently at 7 frames ?
Phone: Pixel 3a (Purple-ish).
Build Log:
Just now, kyro J said:
i have the latest drivers yes
yes i have xmp on
yes its constantly at 7 frames
Make sure you have nothing running in the background
Also while I know a320 can't oc check your VID using hwinfo64
Try a different game
Ddu
Build Log:
Ddu
nothing is running in the background
ill try your suggestions and give an update as soon as im done
46 minutes ago, kyro J said:
so i tried it but still no luck .
What voltage do you have ?
Trying a different game results in same thing ?
Build Log:
i have a 450w psu
i tried a different game and it resulted in the same thing
use hwinfo64
check your voltage
Build Log:
