For a few weeks now whenever i startup minecraft my GPU fans go max speed, i have a surface book 2 with a gtx 1050 so there isn't any way i can control my gpu fan. I also play GTA V which is way more graphically intensive and that is way quieter than minecraft, i have even tried switching minecraft to the intergrated graphics and it still happens, so please help me with this issue, it's getting really annoying, Thanks!
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/
The GPU and CPU share the same cooling solution, and since minecraft is really CPU dependent i guess the CPU runs hot at full load.
My suggestion is to reduce the minecraft CPU load, first install optifine, set render distance to 10 chunks,  limit the FPS to your monitors refresh rate, enable VBOs, enable smart animations ,smooth fps ,fast render , and fast math in performance options..
Also i suggest you monitor your CPU and GPU temps while gaming.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689484
I have already changed all of those settings, I know it's my GPU because the GPU is in the bottom part of the laptop and the CPU in the top part. @Void Master
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689494
Can you monitor your CPU and GPU temps while playing ?
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689500
The GPU was at 60 when i started up minecraft but dropped to 50 because the fan started revving up and all CPU cores were are at about 70 degrees @Void Master.
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689532
The GPU was at 60 when i started up minecraft but dropped to 50 because the fan started revving up and all CPU cores were are at about 70 degrees.
weird....
it sounds like a firmware bug...
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689541
I've also updated the drivers but still same issue, and it's only with minecraft. On other more GPU intensive games it goes way quieter @Void Master.
Did u reinstall minecraft and java ?
Can you update your laptop'[s BIOS ?
and be sure to read all the warnings and precautions before doing that, or else you will brick your laptop.
DON'T TURN IT OFF DURING THE PROCESS EVEN IF IT TAKES A LONG TIME AND DOESN'T RESPOND FOR A WHILE.
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689578
Reinstalling minecraft fixed the issue! Can't believe i didn't think of that. Thanks!
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689607
XDDDDDDD
You're welcome !
https://linustechtips.com/topic/1205874-gpu-fan-100-speed/#findComment-13689610
