[Help] Overclocked RAM
Go to solution Solved by svmlegacy,
6 minutes ago, Escanors said:
Anyone is able to tell me if it'll safe for my ram or not ?
As long as your voltages and temperatures are safe, it should be fine. Your voltage is the same as stock, so no worries there.
Hello, my question is quite simple but the answer is not easy to find depending of forums, so I'll ask myself.
I would like to know if my ram overclock is safe or not (if I can damage my ram by overclocking it).
So my RAM is a Trident Z RGB F4-3200C16D-16GTZR 2*8 Gb, 3200Mhz 16-18-18-38 1.35v.
And I Overclocked it to 3766Mhz 18-22-22-42 still 1.35v.
I ran a Prime95 test with RAM stress for 2h and it's stable.
https://linustechtips.com/topic/1203975-help-overclocked-ram/
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1203975-help-overclocked-ram/#findComment-13673823
^ this and as long as your soc voltage is reasonable your good to go
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1203975-help-overclocked-ram/#findComment-13673825
2 minutes ago, yaboistar said:
you cannot damage ram or cpu's by asking them to run "too fast". excessive voltage damages them.
Thanks everyone for the fast and clear answer !
https://linustechtips.com/topic/1203975-help-overclocked-ram/#findComment-13673841
