My pc config is:
Processor: Amd Fx8350
Motherboard: Ga-990fxa-UD3
Ram: 4sticks of 8gbrams. Total 32gb VULCAN 1600mhz
GPU: RX 550
Windows 10
So my problem is that the system is showing i have 28gb of rams and only 24gb is usable. I checked all the rams on another computer and they worked perfectly.
I just want to know where and what the issue is? and if its fixable?
Also i dont know why the rams are running at 1333mhz.
Please reply ASAP. TIA
https://linustechtips.com/topic/1203946-need-help/
